Текущее время: 06 окт 2026, 00:33
Начать новую тему Ответить на тему  [ Сообщений: 195 ]  На страницу Пред.  1 ... 16, 17, 18, 19, 20  След.
 Заголовок сообщения: Re: обороти мотора
СообщениеДобавлено: 20 янв 2013, 15:39
SuperBee
http://www.thirdgen.org/techboard/tech- ... d-oil.html
пишет five7kid
If your '86 has the factory engine, it has flat tappet lifters. The SM-SN oils also have a rating called "ILSAC GF-4" or "GF-5". To get that rating, you have to limit the amount of "ZDDP" (short for "zinc dialkyldithiophosphate"), an anti-friction additive that is critical for high-load shear applications. Which is exactly what you have with flat tappet lifters. Any engine that requires an SM or SN oil will have roller lifters, so the low ZDDP isn't an issue.
You should use an oil that has a SL/CI-4+ rating. The "CI" is a diesel rating ("C" = "compression", as in "compression ignition"), and the "SL" means it is also rated for a gasoline engine ("S" = "spark", as in "spark ignition"). You don't want to use a CJ-4 rated diesel oil, because it also will have reduced ZDDP.
Sorry, romance, you are dead wrong about oil bases not breaking down. While the VI improver additives are usually the first motor oil constituent to break down, a cheap base will be the next.
These "what oil" threads usually turn into flame wars, because of biases and misinformation (usually un-information). Hope that doesn't turn out to be the case here, but I'm not going to hold my breath.
Тебе нужно масло с допуском не выше API SL. Большинство масел сейчас имеют SM и SN (дальше в алфавитном порядке чем выше буква тем современней допуск), в них уменьшено количество антифрикционной добавки ZDDP (zinc dialkyldithiophosphate) и это не имеет значение для распредвала с роликовыми гидриками, но для твоего имеет
СообщениеДобавлено: 20 янв 2013, 15:52
СообщениеДобавлено: 20 янв 2013, 15:59
Авто: Mustang GT
http://www.competitionproducts.com/Elgi ... ucts/2119/ :popcorn
СообщениеДобавлено: 20 янв 2013, 16:23
SuperBee
он пишет что не только SL должно быть но и CI-4+, так как бывает к примеру SL/CJ-4 в котором тоже уменьшено содержания цинка.
Если вбить в поисковик SL CI-4 (я пока не разобрался что значит "+") то выдает восновном Хадо, а я этому маслу не доверяю
http://xado.ua/masla/mineralnie-motorni ... 40-sl-ci-4
и еще пару какихто странных масел для грузовиков
http://alphaglobal.com.ua/production/fu ... lci-4.html вроде немецкое
вот американское масло Polo SYN PRO 500 с таким рейтингом
http://www.polo.ua/oil10w40.php
SYN PRO 1000 RACING
http://www.polo.ua/oil0w50.php
API CI-4/SL
Кстати у Polo в характеристиках указывается содержание цинка, что подтверждает то что говорил америкос.
Берем любое их масло API SM/CF http://www.polo.ua/oil5w40.php
Цинк, % мас 0,08
Теперь берем любое их масло API CI-4/SL http://www.polo.ua/oil0w50.php
Цинк, % мас 0,13
Походу если ты собрался строить двигатель на Flat tappet распредвале, то с тебя еще один ящик пива :hahaha:
СообщениеДобавлено: 20 янв 2013, 18:10
если заморачиваться с заменой голов, то только на люминий, пусть даже на самые дешевые... ИМХО
СообщениеДобавлено: 20 янв 2013, 18:19
Авто: Mustang GT
а мне вот интересно, неужели нельзя как-то эти чугунные доработать? Я просто еще не рассматривал в серьез этот вопрос. Чугун лучше как минимум в том плане, что его не ведет. какое отличие у алюм.голов?
СообщениеДобавлено: 20 янв 2013, 18:59
SuperBee
Хватит советов на сегодня!
:hahaha:
СообщениеДобавлено: 20 янв 2013, 23:23
Вот чувак чугунные 5.0 доработал. Эта ссылка висит на главной странице тригена в technical articles называется Daniel Burk's 'Porting the GM 305 Cylinder Heads' http://www.ws6transam.org/ported.html
вот что он по мотору делал http://www.ws6transam.org/305HO.html
пишет что квотер проехал за 14.04
СообщениеДобавлено: 21 янв 2013, 00:12
Да это немецкое масло, основатель JB German Oil GmbH & Co Юрген Баумгартен (мотогонщик, автогонщик, каскадер) ;)
В Днепропетровске есть официальный представитель.
СообщениеДобавлено: 21 янв 2013, 00:14
SYN PRO 1000 RACING
POLO
Эксклюзивный дистрибьютор торговой марки POLO в Украине
ООО «БИО» (г. Киев)
Тел. (044) 219-25-80, 81, 82
Факс (044) 219-21-84
